It is currently Mon Jul 06, 2026 3:47 pm
kx250frider617
Post subject: Re: 2015 Axis Plug n play plumbing in rear lockers Posted: Sun Jun 21, 2015 11:36 pm |
Hmm, yours guys rear bag drains are set up way different than mine.
I have two bag drains: 1 goes into the front of the tank, the other goes to a T-fitting that is connected straight to the pump. My bag and tank drain at the same time.
alehr151
Post subject: Re: 2015 Axis Plug n play plumbing in rear lockers Posted: Mon Jun 22, 2015 11:23 am |
My T23 only has two hoses. I noticed yesterday when I was out one of them got kinked and needs to be replaced i would recommend turning the bags at a slight angle to prevent this
SomeYeahoo
Post subject: Re: 2015 Axis Plug n play plumbing in rear lockers Posted: Tue Jun 23, 2015 10:28 am |
I don't know why they tuck that one way up there. I had to call the dealer to get the info in this thread. It was surprisingly hard to find.
ARpowhound
Post subject: Re: 2015 Axis Plug n play plumbing in rear lockers Posted: Mon Aug 31, 2015 5:13 am |
Joined: Wed Aug 27, 2014 5:39 pm Posts: 152 Location: Lonoke, Arkansas
Hodi42, where did you buy the elbow you have on the rear drain quick connect? Is it a barb end elbow on both ends? With a short piece of hose connecting to quick connect fitting? I was thinking of doing the same thing, so I could move the bag back all the way. Nice post. Thx.
_________________ 2013 A22 Black/Orange - SOLD 2017 T23 Black/Orange Flake-(409 2277, Wakemakers 865# rear, 400# bow)
alexandera
Post subject: Re: 2015 Axis Plug n play plumbing in rear lockers Posted: Mon Aug 31, 2015 7:05 pm |
Wakemakers has them... I used 2 barbed 90s in lieu of two quick disconnect fittings.
_________________ -aha-
PotatoShack
Post subject: Re: 2015 Axis Plug n play plumbing in rear lockers Posted: Mon Aug 31, 2015 7:35 pm |
Joined: Tue Aug 21, 2012 5:42 am Posts: 333 Location: College Station Texas
Question. Why not cap the vent line from hard tanks and move vent to PNP bag eliminating the Y fitting.
ARpowhound
Post subject: Re: 2015 Axis Plug n play plumbing in rear lockers Posted: Mon Aug 31, 2015 7:51 pm |
Thx. I found that one on Wakemakers. The reason for the 2 vents, are so the hard tank won't need to be "burped". Should help it drain better. Some don't have a vent on the bag, but then you need an air vent cap in the top of bag to let air out. So why not vent both. I have read that some say you need a check valve on the vent hose to keep it from siphon draining.
Users browsing this forum: Google Adsense [Bot] and 6 guests |
