It is currently Sun Nov 15, 2026 5:33 am
 Post subject: Re: 2015 Axis Plug n play plumbing in rear lockers
PostPosted: Sun Jun 21, 2015 11:36 pm
Hmm, yours guys rear bag drains are set up way different than mine.
I have two bag drains: 1 goes into the front of the tank, the other goes to a T-fitting that is connected straight to the pump. My bag and tank drain at the same time.
PostPosted: Mon Jun 22, 2015 11:23 am
My T23 only has two hoses. I noticed yesterday when I was out one of them got kinked and needs to be replaced i would recommend turning the bags at a slight angle to prevent this
PostPosted: Tue Jun 23, 2015 10:28 am
I don't know why they tuck that one way up there. I had to call the dealer to get the info in this thread. It was surprisingly hard to find.
PostPosted: Mon Aug 31, 2015 5:13 am
Hodi42, where did you buy the elbow you have on the rear drain quick connect? Is it a barb end elbow on both ends? With a short piece of hose connecting to quick connect fitting? I was thinking of doing the same thing, so I could move the bag back all the way. Nice post. Thx.
2013 A22 Black/Orange - SOLD
PostPosted: Mon Aug 31, 2015 7:05 pm
Wakemakers has them... I used 2 barbed 90s in lieu of two quick disconnect fittings.
-aha-
PostPosted: Mon Aug 31, 2015 7:35 pm
Question. Why not cap the vent line from hard tanks and move vent to PNP bag eliminating the Y fitting.
PostPosted: Mon Aug 31, 2015 7:51 pm
Thx. I found that one on Wakemakers.
The reason for the 2 vents, are so the hard tank won't need to be "burped". Should help it drain better. Some don't have a vent on the bag, but then you need an air vent cap in the top of bag to let air out. So why not vent both. I have read that some say you need a check valve on the vent hose to keep it from siphon draining.
Users browsing this forum: Google Adsense [Bot] and 18 guests
