It is currently Fri Oct 23, 2026 2:57 pm
Robert95z
Post subject: Re: Depth Finder Install Posted: Tue Aug 04, 2015 12:36 am |
Here is a picture of the connector. Should be on the starboard side inbetween the engine and the transmission.
| Attachments: |
r33pwrd
Post subject: Re: Depth Finder Install Posted: Tue Aug 04, 2015 7:03 am |
Joined: Sat Jun 06, 2015 10:35 pm Posts: 1181 Location: Sammamish WA
Thanks... so was your above the transmission or down on the side more? Mine must be covered by something? Or I'm just blind..
_________________ -2015 A24 - 409 HP - 2249 Prop - 1100 rear sacs - 950 front sac - 290lb rider with Red Rocket and Phase 5 Quest
r33pwrd
Post subject: Re: Depth Finder Install Posted: Tue Aug 04, 2015 3:06 pm |
Note to A24 owners (possibly others) the transducer is designed to go next to the front ballast pumps not in the rear by the transmission (per Axis tech support). The plug is right under the large plastic access panel under the carpet. I had to run the wires over the gas tank as I installed the transducer before finding plug (Im a dumb ass but it will still work fine)
baz787
Post subject: Re: Depth Finder Install Posted: Mon Sep 21, 2020 5:36 pm |
Joined: Sun Apr 22, 2018 8:42 pm Posts: 13 Location: Annecy, France
Got install instructions from Axis in case anyone finds them useful
| Attachments: |
_________________ --------------------------------------- 2011 Axis A20 with GoSurfAssist Indmar AR335 5.7L
Users browsing this forum: No registered users and 5 guests |
