It is currently Fri Oct 23, 2026 2:56 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Depth Finder Install
PostPosted: Tue Aug 04, 2015 12:36 am
Here is a picture of the connector. Should be on the starboard side inbetween the engine and the transmission.
PostPosted: Tue Aug 04, 2015 7:03 am
Thanks... so was your above the transmission or down on the side more? Mine must be covered by something? Or I'm just blind..
PostPosted: Tue Aug 04, 2015 3:06 pm
Note to A24 owners (possibly others) the transducer is designed to go next to the front ballast pumps not in the rear by the transmission (per Axis tech support). The plug is right under the large plastic access panel under the carpet. I had to run the wires over the gas tank as I installed the transducer before finding plug (Im a dumb ass but it will still work fine)
PostPosted: Mon Sep 21, 2020 5:36 pm
Got install instructions from Axis in case anyone finds them useful
2011 Axis A20 with GoSurfAssist
Indmar AR335 5.7L
