It is currently Fri Sep 25, 2026 9:01 am
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Acme 2079 prop
PostPosted: Sun Apr 07, 2013 9:04 am
So I just got the jumbo fat sacks 1100'2 and was wondering what prop I should order? I've been looking at the Acme 2079. I already own the 1235. Does anybody else have the 2079? Any suggestions would be great.
 Post subject: Re: Acme 2079 prop
PostPosted: Sun Apr 07, 2013 1:15 pm
sorry stuart, I too have been wanting some feedback on this prop. I think there are a couple guys on here with a 2079 but not sure if they have been able to use their boats yet.
If you can, will you go load up your ballast and do a couple timed runs from say, 0-23, note the RPM's at 23 mph, and get us a top speed of your 1235. Then when, or if, you get the 2079, do the same exact thing?
PostPosted: Sun Apr 07, 2013 2:26 pm
It's going to be a few weeks till I get my boat in the water. I called ACME and they also recommended this prop as my best option. I think Im going to pull the trigger on it anyway but was hoping for some feedback on the 2079. If/ when I get it, I will let everybody know my thoughts on the 2079. I was reading that for over 3000 lbs this is my best option and I can still get speed over 30 mph if need be.
PostPosted: Sun Apr 07, 2013 6:27 pm
I just ordered a 2315 along with two sumo 900's in the back. My boat is currently tore down. I'm halfway through the dripless shaftseal install. I had a bitch getting the v-drive cooling hoses off!
When I'm done, I'll take mine out fully loaded and see what time I get. You should be relatively similar with the 2079.
PostPosted: Sun Apr 07, 2013 8:09 pm
Will the 1235 even get the boat on plane with BOTH 1100's full plus all tanks and bow sac with crew?
PostPosted: Sun Apr 07, 2013 8:15 pm
What motor and what altitude? I'd say maybe but it may take a pretty good while.
PostPosted: Mon Apr 08, 2013 2:36 pm
I know my A22 with standard engine struggles big time trying to get all ballast tanks, bow sack, two 750's, and wedge with crew of 4 using the 1235. I rarely ride that much weight and was more of an experiment.
PostPosted: Mon Apr 08, 2013 3:58 pm
I put the 2079 on my boat and it brilliant! pulls like a tug boat! i used to have the 1235 on my a20 and i couldnt plain with full plug n play and wedge but now WOW heaps better on fuel too!
PostPosted: Mon Apr 08, 2013 5:19 pm
Thanks so much for all the input. Looks like the 2079 is going to be the way I go!!!
PostPosted: Mon Apr 08, 2013 7:36 pm
If you wait about another week, I will have my 2315 on and will give you some numbers and feedback.
Users browsing this forum: Majestic-12 [Bot] and 10 guests
