It is currently Mon Oct 26, 2026 11:54 am
 Post subject: Tsunami carpet/pad real slippery.
PostPosted: Mon Feb 11, 2013 3:49 pm
I have the tsunami car/pad in my 2012 A22 Axis and when it gets wet it gets very slippery. I have had a number of people slip and fall or slide and slam their feet into the seat frames. Does anyone else have this issue. Or does anyone have any suggestions on how to fix it?
Thanks.
 Post subject: Re: Tsunami carpet/pad real slippery.
PostPosted: Mon Feb 11, 2013 5:40 pm
I have never had a problem with mine.
PostPosted: Mon Feb 11, 2013 6:45 pm
Did you wash the inside of the boat with soap? Mine was like that once when I didn't rinse out the mat completely and hang it up to dry. Since then I remove it before washing and just spray it off and let it hang dry.
PostPosted: Mon Feb 11, 2013 7:25 pm
@ Walter. I will try that. It has been slippery from the day I got it.
PostPosted: Mon Feb 11, 2013 8:41 pm
Are you referring to the tatami mat? No problems with mine whatsoever.
PostPosted: Mon Feb 11, 2013 9:04 pm
@AJ I guess that's what I'm talking about. I thought it was called tsunami?
PostPosted: Mon Feb 11, 2013 9:06 pm
It was the upgrade from the normal carpet. It's not supposed to get hot or mold.
PostPosted: Mon Feb 11, 2013 9:44 pm
Mine gets hot only when dry, if the sun is directly on it in the middle of the summer you can burn your feet, I've done it.... Now I test it out if its dry and usually end up pouring a bottle of water on it before climbing in
PostPosted: Tue Feb 12, 2013 12:53 am
Walter and I are from Texas so our tatami mats tend to get pretty damn hot still a few months out of the year. Hot enough you can't stand in one place for than a few seconds if its totally dry.
PostPosted: Tue Feb 12, 2013 8:03 am
Ya. I'm from south Texas too. I didn't have that problem with it getting to hot. Just being slippery, but like you said it only did that when it was dry and mine says pretty wet with everyone getting in and out. We really don't just sit and hang out.
