It is currently Fri Oct 23, 2026 4:31 am
 Post subject: Re: TRAILERING BOAT WITH COVER ON IT.
PostPosted: Tue Sep 18, 2012 1:04 am
I've done a number of long trips with the cover off and was Ok until the last trip. The cover was dry the whole trip but I'm not sure if it got loose and allowed the zipper to scuff the boat. Next time I'll just add something extra to ensure it doesn't repeat and make sure it is tight.
For trips to the local lake (30 minutes) we just take the cover off at home.
http://www.vm-help.com/Boat/cover_mark.jpg
PostPosted: Sun Sep 23, 2012 8:57 pm
Never had a problem trailering with a cover...then again I make sure its nice and tight though...but with anything some will be good and some will be bad...just like cars and boats...some people have problems and some don't....
PostPosted: Tue Sep 25, 2012 12:55 pm
Just make sure it is very tight and you ae using the support pole. I towed mine 5 hours each way to Table Rock with no issues whatsoever and I will do it this way again no doubt!
PostPosted: Tue Sep 25, 2012 1:16 pm
x2 with spyderwebb... also, for long trips (3+) wrap the rub rail with plastic wrap, go around once or twice. Start and end at the bow, then throw on the cover. it helps preventing scuffs from cover flapping.
