It is currently Fri Oct 30, 2026 10:09 am
 Post subject: 20 hours blown transmission??! FML and my summer
PostPosted: Sun Jul 08, 2012 2:35 pm
So on my summer vacation this year I took off work to be able to use my new A22. FIRST! day there boat started to cut off for no reason, and I would loose my dash and all power to ignition switch. I believe I fixed that when I tightened a very loose ignition wire behind console. Then I was going to show my buddy how the cruise control worked so he could drive and I could board. Go to come up on plain, and its like it just slipped out of gear ( i thought i had spun the prop off). Boat will idle, but will not go into forward or reverse, like nothing is engaging. took to a local dealer on the lake who deals with supra's took a look at it and thinks its either the transmission or v drive. Anyone every heard of these transmissions going bad at such low hours?? or v drive. very frustrated for obvious reasons, had this boat for a month......its at a axis dealer now.
 Post subject: Re: 20 hours blown transmission??! FML and my summer
PostPosted: Sun Jul 08, 2012 5:18 pm
Never- hope it turns out to be something more minor. Good thing it's under warranty, those v drives are pricey.
PostPosted: Sun Jul 08, 2012 6:51 pm
Something similar happened to me. Turns out the throttle cable came unhooked at the motor. If you remove the access panel under the rear seat you can see where it attaches at the motor. There is a slide clip that holds it place. It was a really simple fix, but gave me the same symptoms you are describing.
PostPosted: Sun Jul 08, 2012 7:58 pm
yeah the tech at the lake said all cables look to be moving and in place. however it was just a quick assessment
PostPosted: Sun Jul 08, 2012 9:06 pm
Just thought if mention it. Good luck.
PostPosted: Mon Jul 09, 2012 1:57 pm
anyone else have any insight??
PostPosted: Mon Jul 09, 2012 2:54 pm
Heard about your boat a few days ago. Sorry bro! Hopefully our marina here puts you on a fast list. I think your trans has went.
Gibby
2011 A22 Vandall
PostPosted: Mon Jul 09, 2012 3:39 pm
My transmission went out at 30hrs. It was a little different than what you described. It started beeping at me saying service,but it still went in gear.You could just feel it slipping.I called the dealer and they thought it was a loose throttle cable,but when I took it in the next day they said it was glazed..If you have plug and play and you sac it out when you ride make sure you have the right prop.I think that was my problem.
Chad
2010 Axis A22
PostPosted: Mon Jul 09, 2012 4:19 pm
thanks gibby, yeah i have been talking to doug since this began. he is good shit. hopefully they can have me on the water before snow is on the ground. And yeah chad i didn't get any alarms, no burnt transmission fluid, no grinding sounds. i had all 3 tanks full but only me and my buddy were on board so i don't think i was putting too much stress on it.
PostPosted: Wed Jul 11, 2012 6:24 pm
well new tranny, and v-drive en route.. hopefully i will be on the water by next weekend. fingers crossed!
Users browsing this forum: Google Adsense [Bot] and 40 guests
