It is currently Mon Mar 23, 2026 11:20 pm
 Post subject: Re: ACME 15x12 (#2315) Prop?
PostPosted: Wed Jun 06, 2012 2:35 pm
Looking at the comparison. 20 seconds is a long time to plane off. My gets to wake speed in about 7 seconds with 3000+ and wedge. Wake is super clean too. I really just wanted to make sure that I didn't make the wrong purchase.
PostPosted: Wed Jun 06, 2012 2:48 pm
You're right on track, I don't like the excessive plane times either, I'm at 2200 ft elevation and with everything full and wedge mine gets to 24mph in about 10-11 seconds.
PostPosted: Wed Jun 06, 2012 4:35 pm
mwilliams0135 wrote:
I think there won't be any comparison between the high altitude and the 5 blade.
What do you mean by this?
PostPosted: Wed Jun 06, 2012 4:40 pm
Saying that the high altitude doesn't have anywhere near the amount of low end as the 5 blade or a wide diameter 4 blade such as the 2315.
PostPosted: Wed Jun 06, 2012 5:03 pm
Actually the 5 blade has slightly less holeshot than the Acme 1235. The 5 blade struggles slightly more with the same ballast setups.
PostPosted: Wed Jun 06, 2012 5:41 pm
Wow. That confirms that I made the right choice. My 2315 15x12 prop. Will plane in about 7 sec. And run about 3600 rpm with all the plug n play extra. Wedge down. 250lb of led in front and 13 people in the boat with a full tank of gas. No struggling whatsoever. I give props to Jim at Acme because he has shot me straight and the prop has delivered.
PostPosted: Wed Jun 06, 2012 8:31 pm
we worked with bill at acme on the 2315 for our MXZ loaded down for surf. I am sticking with that prop for my MXZ. We went thru the regular malibu issue prop, 1235 and then the 2315. I did not even know a wakeboard boat would do over 25mph.. :) so I do not miss the top speed..
Acme makes a great prop and I have never owned anything other than a Acme. I have worked with Bill and Jim at Acme for years and those guys know props!
PostPosted: Wed Jun 06, 2012 9:17 pm
The 2315 sounds awesome, wonder about fuel consumption.
PostPosted: Wed Jun 06, 2012 11:03 pm
mwilliams. Sounds like you got a great prop there. I would love to get one and do a side by side with it. I may have to call acme at the end of the season...
What motor do you have and what pnp bags are you running in the rears?
PostPosted: Wed Jun 06, 2012 11:14 pm
AJ... it burns some gas if you are driving fast.. I really never paid attention to the gas consumption but I have heard that you will burn more at higher speeds not sure about at lower.
