It is currently Sat Jul 05, 2025 7:33 pm
 Post subject: Re: Plug & Play Hookup, Hardtank Fill First.
PostPosted: Tue Jun 05, 2012 12:14 pm
That's a good idea there
PostPosted: Tue Jun 05, 2012 3:51 pm
amsugg wrote:
I installed my rear pnp with a Y selector valve. this way when i want to fill my the pnp sac I can open the valve and fill both hard tank and pnp at the same time. still drains the same way but i think it fills a little faster
Can you tell me where a guy can get this on/off y connector? What size fits the stock hoses?
PostPosted: Tue Jun 05, 2012 4:19 pm
Yeah I was unable to find a cool y valve so I settled for a typical garden hose valve available at your local lowes/home depot. I also purchased the ends to make the hoses connect to the y valve there as well. I would like to say the are 3/4 but I took a small piece of hose to make sure I purchased the correct hose fittings
Not the cleanest I'd say I'd love for it to be all hidden but this was quickest way and so far works pretty well with no leaks
PostPosted: Thu Jun 14, 2012 7:22 am
Does this way help with the full pnp sac pushing water out past the drain pump like others have mentioned? Seems like this would only help with fill times.
PostPosted: Thu Jun 14, 2012 11:27 am
if you refering to pusing past the drain pumps on filling then with the valve open to to both yes closed to pnp no. if your refering to the sac leaking down while filled i have never had that problem. It does not help with drain times. i thought about flipping the sac around and having the drain for the sac Y into the the drain for the hard tank so the pump could pull from both at the same time. but i would have to change a few things and so i decided not to
