It is currently Tue Nov 11, 2025 9:13 pm
 Post subject: Cocked steering wheel
PostPosted: Wed May 02, 2012 11:49 am
Is anybody else steering wheel off? mines probably 15 -20 degrees off. just wanted to know if there was a simple solution before i go pulling the steering stuff apart
 Post subject: Re: Cocked steering wheel
PostPosted: Wed May 02, 2012 12:10 pm
... as in off to the right or left?
PostPosted: Wed May 02, 2012 1:18 pm
at first it was to the left. but i took the steering wheel off (8 or so allen bolts ) and turned it cause it looked like it was just one bolt off but i was wrong now its to the right almost exact same
PostPosted: Thu May 03, 2012 5:19 pm
it should be pretty easy to fix. You should be able to take the steering wheel off and straighten the rudder and put the wheel back on.
PostPosted: Fri May 04, 2012 10:29 am
if your talking about the small allen head bolts then unfortunatly the spacing doesn't work. but i haven't removed the big nut in the middle to release the hub from the shaft which was my next thing to try
PostPosted: Fri May 04, 2012 7:40 pm
that is what I meant. remove the steering wheel completely. you may need a puller.
but most auto parts stores will let you borrow or rent one. good luck
PostPosted: Fri May 04, 2012 8:16 pm
Yeah I work for a shop. I got one from work
