It is currently Sat Jul 05, 2025 9:45 pm
 Post subject: Speed Control
PostPosted: Wed May 02, 2012 5:32 am
How does the speed control go in the axis compared to perfectpass gps? Does it ever speed up when driving double ups or sharp turns?
 Post subject: Re: Speed Control
PostPosted: Wed May 02, 2012 6:48 am
I think it is much better than the PP in my last boat, but that is probably more due to the fact my last ride was an I/O.
PostPosted: Wed May 02, 2012 8:05 am
I never have to take very tight turns (like for small rivers) but my turns aren't wide either and I've never had an issue with the speed control doing anything I didn't like or expect. It may slow down a couple mph and then resume but it's not jerky or unexpected. I like how it works since turns are usually relax time for me. I've done a few double up passes for friends and it did fine...they never complained about speed inconsistencies and did their desired tricks
PostPosted: Wed May 02, 2012 11:50 pm
Mine gets a little crazy on really sharp turns when its dumped. I have found that the trick is just to turn it off before the turn and back on about half way around it!
PostPosted: Thu May 03, 2012 3:13 pm
It holds the speed very well. I consistently ride in a river where I turn sharp and the boat does an awesome job of tracking and holding speed.
PostPosted: Thu May 03, 2012 5:16 pm
I never noticed any issue in tight turns. we ride in a slough that is really narrow.
PostPosted: Fri May 04, 2012 10:06 pm
I've had it screw up a couple times when we've done tight turns when we didn't feel like driving a double up. The boat will suddenly think it's going SUPER slow and continue to floor it til you manually throttle it back. It whipped my buddy up to 35-40 once while he was riding when that happened. Now, we just try to avoid scenarios where a super tight turn is warranted...
2011 A20
PostPosted: Fri May 04, 2012 10:44 pm
My friend's Moomba does that in tight/medium turns with the Moomba digital cruise they use. You have to cut to the inside to avoid getting whipped out. Doesn't make for resting during the turn...which I like to do.
PostPosted: Sat May 05, 2012 10:56 pm
No I mean it literally kept accelerating and never stopped. The rider was in the middle but the boat took him up to 35-40 and we had to manually back off on the throttle. Was kinda scary...
2011 A20
PostPosted: Mon May 07, 2012 9:00 am
Never had that issue of taking the rider to warp speed
Users browsing this forum: Google Adsense [Bot] and 78 guests
