It is currently Fri Oct 23, 2026 4:58 pm
 Post subject: increased center bilge output after a few hours of surfing
PostPosted: Thu Aug 13, 2020 10:21 pm
Do I have a leak in the ballast bags?
 Post subject: Re: increased center bilge output after a few hours of surfi
PostPosted: Fri Apr 30, 2021 10:30 pm
Do your rear cup holders have holes in the bottom?
I put electrical tape over the holes and it helped a bunch!!
PostPosted: Mon Sep 27, 2021 2:01 pm
I noticed that my bilge will come on during a day of surfing. Id check around and see if you have any leaks from the ballast bags or anything around the engine area. If you have a big issue your pump would probably have a hard time keeping up.
PostPosted: Thu Feb 03, 2022 4:50 pm
I had the same issue. After a day of trying to find where it was coming from, I found it coming from under the rub rails. There must be a section of separation where the two molds come together. Check to see if the carpet in the rear lockers is wet. Definitely going to be an off season fix.
Users browsing this forum: No registered users and 1 guest
