It is currently Wed Sep 23, 2026 11:52 pm
 Post subject: Service Engine Soon-code stored ECM: SPN 65598 FMI 7
PostPosted: Mon Jul 07, 2014 11:36 am
So what is this error. Boat seems to run fine but the annoying beep every so often is driving me nuts.
2013 A22
Last year right after purchase I got a code like this don't remember the number or code. The dealer told me it was just a spark plug so I am assuming this is the same code back again. They changed the plug and cleared the code.
Does that mean Spark plug notice #8 cylinder? How can I make sure the dealer gets this resolved this go around. I am a pretty good haul from the dealer as it is. Why would the engine foul spark plugs anyway?
I have auto enginuity software for OBD II and non OBDII diesel trucks so what scan tool do I need and where is the test pport located on my boat? Because I tried disconnecting the batteries for a while and it did nothing. There doesn't seem to be a way to clear the code through the instrument panel either.
Thanks in advance for any input on this topic
Adrian
 Post subject: Re: Service Engine Soon-code stored ECM: SPN 65598 FMI 7
PostPosted: Mon Jul 07, 2014 12:04 pm
I hope this helps. I googled it.
Entire manual found here.
https://www.bakesonline.com/images/Medi ... manual.pdf
PostPosted: Mon Jul 07, 2014 12:05 pm
I would suggest checking the distributor cap and all the plugs.
PostPosted: Sun Jul 14, 2019 6:57 pm
Hi boys.
Sorry for thé english. French speaking 99% of the Time !
I had the same problem. I’ve seen two dealer , 2 solo mechanic ... still having problem off engine shouting down when running engine about 20-25 mph.
And off course it’s à intermittent problem.
We have change cap rotor Twice! All spart plug and cables, 8 injector , no water in tank. Changed the fuel filter.
The only thing I could think off would be sensor.
I have been told There is 2 for the injector... one for Low speed and one if There is more Power....
Axis 2012 a22 With indmar 5,3 ltr
Anyboby have encounter the same problem?
Thanks in advance !
Envoyé de mon iPhone en utilisant Tapatalk
PostPosted: Fri Aug 02, 2019 3:19 pm
I just had the cylinder one code.. i was about to do all the plugs when a great local mechanic said just check ur cap and rotor first.. thats the weak point on our boats.. they are for sure. I changed mine as it was extremealy corroded on all the points and got the code cleared.. code has t come back yet so.
Sent from my SM-G955W using Tapatalk
PostPosted: Sun Aug 04, 2019 2:55 pm
Did you replace just the cap and rotor or the entire distributor? I have the same problem and was trying to figure out which to purchase.
PostPosted: Sun Aug 04, 2019 5:22 pm
I just replaced cap and rotor.
PostPosted: Sat Aug 10, 2019 8:25 am
I keep getting the cylinder 1 misfire code, and my boat runs fine. I ended up biting the bullet and buying the reset tool($700) because it seems to pop up after a decent jolt over a wave, and I don’t want to run to the dealer every time it comes on. My next steps will be cam position sensor and knock sensor, but I’m told it may just be some bad software in the MEFI Unit. I’d be willing to rent my “techmate pro” for those that just want to clear the error.
PostPosted: Tue Aug 27, 2019 11:10 am
Did the reset fix your problem? I’ve done my cap, rotor, plugs, and wires but can’t get it to reset with the three fast starts.
PostPosted: Mon Sep 23, 2019 12:01 pm
3 fast starts? What is this?
Users browsing this forum: No registered users and 71 guests
