It is currently Fri Nov 20, 2026 12:33 am
 Post subject: Amplifier location
PostPosted: Mon Jan 14, 2019 1:21 am
Hey guys,
2016 a20
Just about to go ahead and do a little project next week with installing some new tower speakers, sub and amp. I know most people mount thier amps in the big storage section on the port side where the battery is. My question is which side of the storage area do you guys use. The starboard side where the isolator switch is which is the wall of the walkway to the bow or the port side which is the outside of the hull. I was planning to use the starboard side. Any help much appreciates
 Post subject: Re: Amplifier location
PostPosted: Mon Jan 14, 2019 6:43 am
You should have an amp board that is mounted on the hull side. That’s where you would want to mount your amps.
