It is currently Tue May 26, 2026 9:40 am
 Post subject: Installing rear bag vents on a 16 t22
PostPosted: Tue Jul 10, 2018 6:57 am
What size is the factory ballast hose? Looked like 1"? Noticed a few post showing a 1 way valve, has anyone tried it without it? I need to get everything coming and the boat is at our cabin thanks for any help
 Post subject: Re: Installing rear bag vents on a 16 t22
PostPosted: Tue Jul 10, 2018 6:30 pm
If you are tapping into the drain line off the hard tank like this, yes you will want a 1 way check valve. Adding the check valve prevents the water to circulate back into the bag. It won't harm anything if you don't add it but it will take a lot longer to drain the bag and tank. Hose is 1&1/8th.ImageImage
PostPosted: Wed Jul 11, 2018 2:05 am
My setup is a little different but it works great as well:
I removed the vent hose from the hard tank and put it on top of the bag. Then I Y-ed into the fill hose and put one end on the hard tank (where it used to be) and one end on the other top port of the bag. Both bag drains go into the hard tank. Worked perfectly for the past 3 years in my 2014 A22.
So I only vent from the bag but I suppose that's fine since the air will always go out the top and can exit the hard tank via the two hoses that come from the bags (bag drains) and then out the bag vent.
2014 A22
PostPosted: Wed Jul 11, 2018 12:10 pm
Thanks, I got everything coming...... Hopefully, I ordered it all from wakemakers and you can't seem to get anyone in customer service on the phone and they didn't answer my question online, let's just say I'm less than happy with there customer service, but they've got the best selection of parts, so I'm stuck. Thanks again for the replies
PostPosted: Thu Jul 12, 2018 8:34 am
Is this just to keep the bags from trapping air? Getting tired or burping the bags myself..
PostPosted: Thu Jul 12, 2018 12:13 pm
Yes, if you do this you can just forget about the bags until they start overflowing out of the drain and 3/4 hard tank through holes.
PostPosted: Thu Jul 12, 2018 4:36 pm
Where is everyone buying the one way valve? Doing this to just rear bags or horseshoe front bag as well?
Thanks
PostPosted: Thu Jul 12, 2018 6:29 pm
Thanks
Just the rear bags, wakemakers has everything you'll need.
PostPosted: Fri Jul 13, 2018 6:31 am
Maybe check bakesonline, they don't have the selection of wakemakers but they do have the stuff and they're competent, wakemakers are still jacking me around and have zero customer service. My order has said processing for 2 days and no one answers the phone or replies online. I'm giving them today to get back with me,then I'm canceling and going elsewhere if I can even do that.
PostPosted: Sun Jul 15, 2018 7:55 am
Yea I'll just stop in there this week and see of they have them..
Users browsing this forum: No registered users and 180 guests
