It is currently Mon Oct 26, 2026 6:02 pm
[ 6 posts ] |
Lumbergh
Post subject: 2014 Axis A20 Surf Setting Dialed In Posted: Tue May 08, 2018 8:04 am |
| Newbie |
Good push and decent pocket.
650's rear, 950 arrow in bow, 350 pounds lead stashed in bow. All tanks full: rear center front. One 200 pound adult in bow. WEDGE DOWN: This was key for us. It was bad without it, but awesome with it. Slightly drained rear right bag until shape was nice. 10.8 mph... no more, no less or it's lost.
Me 180 pounds Phase 5 Danielo Diamon carbon fiber board
Took me FOREVER to dial it in because I didn't have a good board and didn't use the wedge.
Oh and the wakeboard wave was insane with full ballast and no wedge. Barely got on plane but it did it.
_________________ 2014 Axis A20 Surf Gate
j2m2t2
Post subject: Re: 2014 Axis A20 Surf Setting Dialed In Posted: Tue May 08, 2018 7:06 pm |
Thanks for the info. I'm working on my 2016 setup, looks like I need more bow weight.
Jmyers
Post subject: Re: 2014 Axis A20 Surf Setting Dialed In Posted: Fri May 11, 2018 8:32 pm |
Joined: Fri Jun 16, 2017 10:29 pm Posts: 10 Location: Oregon
When you say “right rear bag” can you be more detailed, as in starboard or port and also which side of the boat your surfing on?
_________________ 2017 A22
HalfKiwi
Post subject: Re: 2014 Axis A20 Surf Setting Dialed In Posted: Sat May 12, 2018 5:02 pm |
| Boater |
Joined: Sun Nov 09, 2014 8:53 am Posts: 49 Location: San Diego
Wow, lead and passenger 550lbs in the bow and a 900 arrow bag. How do you keep from swamping the boat.
granddaddy55
Post subject: Re: 2014 Axis A20 Surf Setting Dialed In Posted: Mon May 14, 2018 7:12 pm |
Never turn indirection of wave side, when coming off throttle turn wheel completely before boat settles , after good nuetral , hard reverse with wheel still turned (rotates boat back and away from coming rollers) so you don’t have to cross any wake remnants , head to your surfer
_________________ 14 A20, 850 rears with kinetic vents, front 950, stock plus wedge and 700 lead P5 53” Ahi, Brigade 4’10” goofy asym, LF Happy pill 4’8”, LF Catalyst Nomad skate, HL wakeboard with old Murry boots
onwi
Post subject: Re: 2014 Axis A20 Surf Setting Dialed In Posted: Tue May 15, 2018 2:12 pm |
Joined: Thu Apr 11, 2013 6:19 pm Posts: 199 Location: SE Wisconsin
If you are barely getting on plane with that weight set up I'd check your prop. I run the 2313 (basically a 2315) and get to wakeboard speed with absolutely zero issue with 750 rears, arrow sac, stock, 1k in bow with or without the wedge.
_________________ ________ 2012 A20
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 14 guests |
