It is currently Sat Sep 05, 2026 5:28 am
 Post subject: Wedge deployed Alert
PostPosted: Thu Apr 19, 2018 1:41 pm
we have a 2015 T23 and the dash alert for when the wedge is deployed does not function.
Anyone have any advice on how to check whats wrong? Physically the sensor on the wedge looks okay.
thanks
2015 T23
 Post subject: Re: Wedge deployed Alert
PostPosted: Thu Apr 19, 2018 1:59 pm
I had this recently on my 17 where the dash always said the wedge was down. My problem was that the little spring between the sensor and the wedge got bent so it wasn’t pushing up far enough when the wedge was up. It was hard to see looking at it.
Try manually manipulating the sensor to see if it changes the dash. If it does then you know it’s working and is a physical problem. If you hear the switch clicking but the dash does not change then it’s electrical.
PostPosted: Thu Apr 19, 2018 4:37 pm
Had the same problem on my 2014 A22. It turned out to be a defective sensor. Looked like water got inside the switch and corroded it. I ended up buying a new sensor.
2014 A22
PostPosted: Thu Apr 19, 2018 6:17 pm
Where did you buy the new sensor?
2015 T23
PostPosted: Fri Apr 20, 2018 12:49 am
My dealer got it for me.
2014 A22
PostPosted: Fri Apr 20, 2018 7:27 am
1st 2.5 years I just bent the spring lever down and would fix problem . I think the bending of lever may be how an opening is created in switch leading to the real failure vs the lever not being in right place, just went outside to listen for the click and I could hear the water bubbling out from the switch when I pressed it instead of a click so there’s your/mine answer
So is it as easy as just unscrew plug at hex head plastic coupler by the transom ? And replace by unscrewing mount snd I assume new switch comes with hex head pigtail
PostPosted: Fri Apr 20, 2018 7:33 am
I’m confused, you are saying sensor is in the switch right, if not where is the sensor ???
PostPosted: Fri Apr 20, 2018 6:17 pm
Don’t have dealer anymore , just sent message to Andrew at bakes to order one and my broken pickle fork rubrail corner wife broke when she hit guide pole a month ago , just noticed it broken last Friday on a surf
PostPosted: Sun Apr 22, 2018 9:22 am
My switch decided to work this weekend after no click being heard and pressing arm upward and hearing the air and water , still ordered the part, it can’t last with the water invasion, but we will see and I’ll hold the new one a while and see how far it goes. The real problem is the wedge down message blocking the depth finder, I may not have bothered to replace if that didn’t happen
I know when the wedge is down
PostPosted: Mon Apr 23, 2018 2:32 am
Sorry for the confusion. Actually it's all in that small part with the metal bracket. Where the cable comes out water got in and after it worked only intermittently, it stopped working completely.
How is your wedge down message blocking the depth finder in a 2014? Isn't the wedge light inside the tachometer and the depth finder in the digital gauge?
2014 A22
