It is currently Mon Apr 20, 2026 2:03 am
 Post subject: Custom GPS controlled surfgate setup
PostPosted: Sat Mar 31, 2018 9:01 am
I just picked up a 2013 A20 and am adding surf gates onto it.
I wrote arduino code to automate the actuators via GPS speeds and shared it on github incase anyone wants to check it out.
Source: https://github.com/jonthompson/surfgate
For a basic version for <$50 you can put together the control system -- obviously the tabs/actuators are another $500+
The "simple" version that is up makes use of:
1 Arduino mega ($10 @ Microcenter)
1 GPS module w/antenna $25 - https://www.amazon.com/dp/B01MRNN3YZ/re ... UTF8&psc=1
1 L298N module for a simple H bridge to control actuator relays - $7 https://www.amazon.com/Diymall-Module-S ... 00NJOTBOK/ (These JUST control the relays, NOT the high draw actuators - this was to keep it simple and avoid having to solder anything custom)
3x momentary LED backlit push buttons to control modes ($5 off ebay.)
Then:
Add standard marine relays + lenco actuators (~$170 each) and make some tabs - and you've got a custom GPS speed controlled surfgate
Basic features: 3 buttons (surf left, surf right, off) - tabs automatically deploy at set speeds (IE: >7mph and <14mph.) If you hold the buttons for a second it enters "override" mode to force deploy of that tab.
I have a more complex version that has an OLED screen + wifi module for phone control/settings via app + RF control for a custom surf band that I'll share there as well once i clean the code up and document it some.
If anyones interested in adapting this on their boat let me know - I have a full wiring diagram I'll share on the github project as well!
 Post subject: Re: Custom GPS controlled surfgate setup
PostPosted: Tue Apr 03, 2018 2:14 pm
I'm looking exactly about a wifi module and remote. For sure I'll be interest in your diagram as well!
English is my second language! I'll do my best!
PostPosted: Wed Apr 04, 2018 12:02 pm
I'll put it together this weekend - traveling this week. The part list is pretty straight forward if you want to grab that in advance. The remote i need to rework as the bluetooth remote i was using is no longer for sale - but it's a simple mod to just straight RF.
PostPosted: Tue Apr 10, 2018 7:47 pm
i am looking to add a surf gate setup to my 2011. Last year i narrowed my platform to make room for tabs. now i just need to build and add the tabs, id love if someone had this all figured out like you seem to. would you consider building a controller? also have you built your tab system to show it working in a video! this is all exciting lol
2011 Axis A22 VANDALL, BLK
PostPosted: Wed Apr 11, 2018 3:53 am
How do you process for re-shaping your swim plafform? Do you have any picture? Have to do mine too!
PostPosted: Wed Apr 11, 2018 6:55 pm
here are the pictures i have. if i remember i cut like 5 inches of width out of it near the boat and the outside corners were like 16 inches narrower. it was fiberglass work so it wasnt pretty during the process but i used it all year and it worked great. it took a ton of time but its worth it. I also had a custom sea deck made for it so it looks factory.
PostPosted: Wed Apr 11, 2018 10:29 pm
(Nice fiberglass work!!)
I actually just picked up a 2013 a20 this spring - so I haven't put the tabs on mine yet as I need to prototype in the water to get the placement right with my slightly-larger-than-a-2014 platform (trying to avoid having to cut down my platform..) but the controller itself is all built and ready to go.
I originally built the controller last fall for a friends boat and it worked great for the season (replaced his manual trim tab buttons.) I refined it some this winter and need to upload the latest code to github that adds a bunch of functionality..
Ice will be out in the next month or so up this way and I can get some video of the controller in the water then on his boat.
I'd be happy to ship the arduino out pre-flashed at cost if that's a concern ($10 from microcenter +shipping) - if you have any soldering skills it's not too difficult. I don't think a screw shield on the arduino would work well bouncing around - maybe epoxied it'd be ok but you'd still need to solder a few parts. I can't offer to build em for folks, I know I wont have the time - but i can try to help if anyone has any questions along the way!
Sorry I haven't had a chance to put up the wiring diagram yet - traveling this week and for the next two but i'll get to it in the next few weeks when my schedule calms down some.. I also dont have access to my boat until early may so that's slowing things down!
PostPosted: Thu Apr 12, 2018 2:54 pm
Wow! Nice work! I'm questionning myself if I cut mind or build a teak deck. I never work with fiberglass and i'm definitely better with wood working!
No worries, there's still 4feets of ice here! :cry: I already order all the parts that you tell on your first post, should get my stuff around next week or so.
PostPosted: Thu Apr 12, 2018 2:58 pm
its messy thats for sure but its forgiving.i probably have 40 hours or so into it by the time i had it painted but like i said it looks factory.
PostPosted: Fri May 04, 2018 8:30 am
Hey all - just a heads up.
This is installed and working well. I posted a "simple" version that uses an uno instead of a mega - since some folks were having trouble finding cheap megas as they didnt have a microcenter nearby. This should work the same for a mega too - but you can use the hardware serial for mega - it should work out of box as the GPSPort code will find the GPS whereever you put it. If you are using an uno you need to have it on pins 8/9 to use AltSoftwareSerial.
You can view the wiring diagram here:
https://github.com/jonthompson/surfgate ... itzing.png
The Uno version of the code (simplified) is available here:
https://github.com/jonthompson/surfgate ... le_uno.ino
Parts involved:
Arduino Uno
L298N Dual H bridge motor controller https://www.amazon.com/Stepper-Controll ... 01GZ1QUHO/ (Drives the relays for the lencos, DO NOT DRIVE THE LENCOS DIRECTLY they draw way too much power, this is just a simple relay trigger.)
GPS module w/antenna - https://www.amazon.com/Gowoops-Ceramic- ... 01MRNN3YZ/
LM2596 step down buck converter to regulate power https://www.amazon.com/Teenitor-LM2596S ... 0748FKKWL/
1 3 way switch (SPDT) -- you can use an axis brand switch for this to look stock - or just anything like: https://www.amazon.com/gp/product/B012MYR518/
If anyone has any build questions let me know. I put mine in a simple cheap junction box - and have aviator connectors for all the wiring leaving the box.
If you want to test with minimal soldering- you can try a screw shield on the ardiuno - but i dont think i'd trust it to hold up long term so once you're happy with it you'll want to solder it in.
