It is currently Tue Oct 20, 2026 1:44 am
 Post subject: Accessory switch question
PostPosted: Mon Apr 16, 2012 9:33 am
Going to install my cabin RGB LEDs this weekend. Looking at the unused switch on the dash, how do these switches come off the dash to get to the back?
 Post subject: Re: Accessory switch question
PostPosted: Mon Apr 16, 2012 10:30 am
I'd like to know as well. There's got to be some tabs you press to pop them out of there. Anyone know which leads are 12v?
PostPosted: Mon Apr 16, 2012 11:21 am
My transom LEDs are hooked up to the on/off switch. I'll be using on/off/on switch for the cabin lights
PostPosted: Mon Apr 16, 2012 8:19 pm
can you take a pic of how the leds are wired into the back on it? Mine came with the white cabins, so I'll prob keep them on the interior switch. Then I'll do red or orange to the accessory.
PostPosted: Mon Apr 16, 2012 8:39 pm
Pics of the transom LEDs wired to the switch or when I get my RGBs hooked up?
PostPosted: Mon Apr 16, 2012 9:49 pm
I want to see your transom LEDs. A pic of the back of the boat. I think I'm going to install some.
Gibby
2011 A22 Vandall
PostPosted: Tue Apr 17, 2012 4:55 pm
back of accessory switch
PostPosted: Fri Apr 20, 2012 6:14 am
To answer the op question, the switches have plastic clips on the top and bottom of each switch. squeeze them and pull switch out. Take a bit of effort and even if you can only reach on clip you can usually wiggle it out.
