It is currently Sun Nov 09, 2025 9:52 am
 Post subject: Oil Change Kit
PostPosted: Wed Sep 06, 2017 2:27 pm
Anyone have any suggestions on what to pick up to do my own oil changes? I have been looking around at a few extractors, but figured you all would have a better idea as to what is best. Thanks!
 Post subject: Re: Oil Change Kit
PostPosted: Wed Sep 06, 2017 4:46 pm
One of these and hit your local hardware store for a fitting that will thread onto your drain tube.
https://www.amazon.com/gp/aw/d/B000GU0M ... BK3C7LO58P
Makes things a breeze
PostPosted: Wed Sep 06, 2017 6:28 pm
Hey bud I dropped some knowledge on your partner! ;-)
I have one like vanamp linked and if I were doing it over again, I'd get a mighty vac or go all-in and get the electric jabsco pump/bucket setup (the Cadillac of extractors).
PostPosted: Sat Sep 09, 2017 12:02 pm
Anyone every use a drill motor style pump like this http://www.homedepot.com/p/AquaPro-Dril ... ZAodzl8ChA
PostPosted: Sat Sep 09, 2017 2:32 pm
The drill style pumps would not be strong enough. I just used one recently to drain a tank and they are wimpy and very little suction.
PostPosted: Sun Sep 10, 2017 5:34 am
I have a hand pump one like the pela but after seeing that jabsco electric I'm gonna have to order one
PostPosted: Mon Sep 11, 2017 10:58 am
Thanks everyone. Got it all taken care of this weekend. Used this extractor https://www.amazon.com/Transfer-Extract ... +extractor
worked like a charm. Just used a home depot 5 gallon paint bucket to catch all of the oil.
PostPosted: Wed Oct 04, 2017 9:38 pm
I just ordered one of these.
Do you know what size fitting you used for this? The boat is 4 hours away, so I just want too make sure I have the right things to winterize
2017 A22
2000 Sunsetter Lxi
PostPosted: Thu Oct 05, 2017 8:03 am
1/2" NPT Female to Barb
PostPosted: Fri Oct 06, 2017 9:17 am
Just wanted to say thanks for the suggestion. I sprung for the jabsco one linked here and it worked very well. I didn't bother threading anything onto the end of the drain hose on the engine, I just ran the clear tube that came with the kit up through the drain hose and sucked everything out that way. I then ran the clear tube down the dipstick hole and got nothing further out of it. It did take about 15 minutes to pump the (warm) oil out, but I had other things to do while it was running. Didn't spill a drop and it was super easy to pour the oil from the bucket into the "new oil" containers once I was done filling the boat.
I had previously bought and tried a mityvac one and I must have had a defective unit because it required me to manually pump the entire time to get anything to suck out (threw it in the garbage). The electric pump was a definite step up.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 37 guests
