It is currently Fri Oct 30, 2026 2:42 pm
 Post subject: 2012 Axis A20 Gas in tank removal
PostPosted: Tue Jun 20, 2017 12:09 pm
Can someone tell me what's the best way to get unwanted fuel out of the gas tank?
I have a full tank and wanting to lightened the load to make a long pull .
Axis Freak
 Post subject: Re: 2012 Axis A20 Gas in tank removal
PostPosted: Tue Jun 20, 2017 12:12 pm
I have tried using a water hose and scoping it through the fill gas line into the tank and have not been successful
PostPosted: Tue Jun 20, 2017 12:16 pm
Axis Freak
[size=150]
[/size]
PostPosted: Tue Jun 20, 2017 1:23 pm
I always did the opposite on long tows, my boat towed smoother with a full tank for some reason.
PostPosted: Wed Jun 21, 2017 6:58 am
I try to pull empty on long hauls as well. I would think the effort or figuring out how to both remove and then store the fuel would be more difficult and time intensive then simply driving to the lake and getting some pulls in. Otherwise, its really easy to remove the floor in the boat to uncover the tank. Could the fill fitting be removed and then the gas pumped out?
________
PostPosted: Wed Jun 21, 2017 7:44 am
Same here.. I have even left a little water in my center ballast before.
PostPosted: Fri Jun 30, 2017 8:38 am
siphon it through the gas cap. and put it in your tow vehicle if it's a gasser.
Try getting a clear hose though, when we did it (put in 87 octane instead of 91) we tasted some gas because we couldn't see it coming.
Sent from my VS988 using Tapatalk
