It is currently Mon Dec 22, 2025 1:31 am
[ 4 posts ] |
waterworkscarwas
Post subject: Delta suction cups Posted: Sun Jun 18, 2017 9:46 pm |
Love the Delta wakeshaper on my 2013 A22 when it sticks the wave is as good as I have seen on any boat. However, getting it to stick can be frustrating and give up sometimes. What is the secret ? I do not think it feels right when I close the suction cups as there does not seem to be mush resistance. Please help .. I just want to surf and stop figuring out how to make Delta stick
morrisdl
Post subject: Re: Delta suction cups Posted: Thu Jun 22, 2017 6:04 am |
Sometimes a problem here...havnt totally figured it out yet either. So far worked out fresh wax bad, dirty bad, leaving the suc cups locked when not using is bad, Suc cup too close to the graphic bad. Thinking about redesigning mine to be three suc cups.
onwi
Post subject: Re: Delta suction cups Posted: Thu Jun 22, 2017 7:31 am |
Joined: Thu Apr 11, 2013 6:19 pm Posts: 199 Location: SE Wisconsin
Currently, the suck gates use one handle (2 cups). Someone should try one with 2 handles (4 cups). I'd make sure the handles run in-line with the direction of the water, just like they currently do. If you put them the other way I assume the front handle would be easier to pull off from the forces exerted by the water.
_________________ ________ 2012 A20
MULakeHound
Post subject: Re: Delta suction cups Posted: Thu Jun 22, 2017 7:12 pm |
Joined: Tue Jun 13, 2017 9:40 am Posts: 51 Location: SW Mo
Are you mounting it on a perfectly flat area? You've also got to push them into the side as you lock to force any water that might get trapped in the cup out.
_________________ 2017 T23 2007 Malibu VTX (Sold)
[ 4 posts ] |
Users browsing this forum: No registered users and 41 guests |
