It is currently Fri Jul 10, 2026 9:38 pm
 Post subject: Auto Volume Help
PostPosted: Tue May 09, 2017 8:15 pm
Can someone please explain the auto volume settings on a 2017 Axis. I purchased a T23 three weeks ago and have not got to use it but for 2hrs so far (thanks rain). Anyways going through the break in period and frequently adjusting speeds I found it somewhat annoying with the varying loudness due to the AV feature. I know I can turn it off but I actually would like the feature if I could set it to my max preferred volume while crusing and then slightly lower when slowing down to pick up a rider or docking. My older Malibu was not quite as fancy so any help would be appreciated.
 Post subject: Re: Auto Volume Help
PostPosted: Sun May 21, 2017 2:49 pm
Auto volume can be adjusted by going into the main menu of the screen on the instrument panel. page 58 in the manual
http://www.axiswake.com/assets/docs/201 ... manual.pdf
PostPosted: Fri Dec 01, 2017 9:42 pm
Thanks
I found this same issue also annoying the first and only time I’ve been able to take out our ‘17 A22.
