It is currently Fri Sep 25, 2026 4:26 am
 Post subject: iphone
PostPosted: Wed Mar 28, 2012 8:08 pm
Will iphone work on the Axis radio? If so does it work though the usb cable. I hook mine up and nothing happens.
 Post subject: Re: iphone
PostPosted: Wed Mar 28, 2012 8:25 pm
My iPod works fine. I think they have the same interface...
Scott
PostPosted: Wed Mar 28, 2012 8:36 pm
Just use your iphone cable to the usb interface. I start my playlist just before plugging in and then you can control it through HU and remote if you have one. If you've upgraded your stereo, I'd make sure to turn off any eq settings on iphone and set volume on it to 75%.
PostPosted: Wed Mar 28, 2012 8:40 pm
mine says no device when I plug it up
PostPosted: Wed Mar 28, 2012 8:47 pm
It is iphone4
PostPosted: Wed Mar 28, 2012 8:50 pm
I would try another ipod/iphone and see if it works. If not you may have a problem with your cable.
Scott
PostPosted: Wed Mar 28, 2012 9:03 pm
And your cycling through menu to usb on HU? That doesn't sound right
PostPosted: Wed Mar 28, 2012 9:04 pm
I've got a 4s and works like a champ
PostPosted: Wed Mar 28, 2012 9:11 pm
No problems with any iPhone generation I've had hooked up, even older iPods.
PostPosted: Wed Mar 28, 2012 9:16 pm
my wife has a 4s and it will not work
