It is currently Mon Sep 28, 2026 11:46 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2, 3  Next
 Post subject: more Ballast
PostPosted: Fri Sep 10, 2010 5:49 pm
Just ordered two of the 24x24x50 sacks from Fly High for the rear ! They are rated at ...1000# each !! Cant wait to get them in and see what the wake is like ! ;)
 Post subject: Re: more Ballast
PostPosted: Fri Sep 10, 2010 9:29 pm
that is a bunch in the back for wakeboarding... You using the 1000lbs just for wakesurfing?
PostPosted: Sat Sep 11, 2010 5:22 am
The extra weight will be great fo4 surfing but is primarily for wakeboarding. Already have the mushroom head sack in the front and I was running 400 s. In the rear with the wedge and a 750 in the floor if I didnt have a boatload of people. I'm going to add 150# is lead to the front when I get the sacks in to help counter the extra in the rear. Anin the rear. Shouldn't have to run the wedge. And I board at 24.2
PostPosted: Mon Sep 13, 2010 6:47 pm
holy crap that's alotta weight!!!!!!!
PostPosted: Tue Sep 14, 2010 7:46 pm
Here is a pic of one of the 1100s. I wear a 13 so you can tell how big these things are ! Ha Ha Ha . cant wait ti fill these bad boys up !
PostPosted: Tue Sep 14, 2010 9:38 pm
that is a big ballast. I have never seen that much in the rear for wakeboarding. I have for surf but not wake. let me know how that works out. You might need more in the nose to get on plane.
PostPosted: Wed Sep 15, 2010 5:39 am
I'm adding about 100lbs of weight to the nose and probably fill one of my 400 rear sacks in the walkway.
PostPosted: Mon Sep 20, 2010 12:43 pm
The 1100's rock. They fill up the rear compartments completely. Had to put my 400 in the front to balance out. But for when we go out with 3 it 4 people it creates a huge wake. I love it ! The wake OS large and rampy withva good kick at rhe top. It's not as wide as when o tan thw wedge befo4e.
PostPosted: Mon Sep 20, 2010 3:34 pm
So what is your weight set up now?
How are you filling the 1100's?
PostPosted: Tue Sep 21, 2010 8:14 am
I'm using the 1100 sacks in the rear in place of the 400 sacks. Just hooked them up to the plug and play. I have the plug n play in the nose and a 400 in the nose as well.
