It is currently Sun Mar 29, 2026 10:56 pm
 Post subject: Temperature Gauge Accuracy
PostPosted: Sat Jul 09, 2016 7:44 am
How accurate are your temperature gauges (air/water)? Mine don't seem to be all that accurate. They seemed to be more accurate in the past, so I asked the dealer to calibrate them when I dropped it off for them to work on the surfgate issue. How high should my expectations be?
 Post subject: Re: Temperature Gauge Accuracy
PostPosted: Sat Jul 09, 2016 8:18 am
Mine are close. Water is almost right on. Air temp is close but normally shows hotter. I've had 4 boats with temp gauges and it's been the same on all of them. Air temp is tough when in the hot sun all day much better when moving.
PostPosted: Sat Jul 09, 2016 10:07 am
My water seems pretty accurate but the air is way off
PostPosted: Sat Jul 09, 2016 10:34 am
my water temp is close, except when its cold, then it reads high, air always reads a little higher than normal.
2013 A20
PostPosted: Wed Jul 13, 2016 8:23 pm
Dealership says mine is working fine. Hmmm....
PostPosted: Fri Jul 15, 2016 7:00 am
Is there a way to calibrate them. My water temp is about 10 low
Users browsing this forum: No registered users and 107 guests
