It is currently Sun Mar 29, 2026 7:25 pm
 Post subject: Re: Lake Powell trip!!
PostPosted: Fri Jul 08, 2016 12:34 pm
gibbs114 wrote:
The surfgate needs bigger fuses. Had the same issue on my 16 T23. I also have the oil issues I've been told by Malibu and PCM that the boat will use oil while running under the heavy loads I run surfing and boarding. I just get a gallon of oil and check it each time before I go out and fill as needed. Boat now has 85 hours and I just started my 2nd gallon of oil.
WTH? I'm at 155 hours and I don't think I've ever added oil between oil changes. Half those hours are surfing with 3400 lbs +people + wedge. What do you have in your boat to burn that much oil?
PostPosted: Fri Jul 08, 2016 1:19 pm
I have heard of some not burning any. But some that burn a lot. I run about 4,500 in ballast. They keep saying its normal but it's hard to believe.
