It is currently Thu Nov 06, 2025 4:31 pm
 Post subject: Wetsounds sub xxx v2
PostPosted: Thu Jun 02, 2016 8:16 am
Has anyone switched out the factory wetsounds xs12 with a wetsounds xxx.
Got 2x rev410 on a SD4.. and need some more bass and the stock sub don't seem to be cutting it.
Want to use the same enclosure if possible, will that work?
Just don't know my mounting options.
would be easiest to take the xs12 out and plug in the xxx as looks like the cutout is the same but has almost 2x the mounting depth.
Going in a 2012 a22
Any help is appreciated.
 Post subject: Re: Wetsounds sub xxx v2
PostPosted: Thu Jun 02, 2016 10:37 am
Are you using a custom built enclosure or is it still free-air? Ideally in a enclosure you want it built to each individual sub's specifications.
PostPosted: Thu Jun 02, 2016 11:50 am
If you have not installed a custom enclosure you are still running free air. I could spend the money on an enclosure first. I would be willing to be your stock sub would provide plenty of bass in the correct enclosure.
Basically, you sub now is mounting to that panel and that is pretty much it. I would also think you would need another amp to drive the new sub.
PostPosted: Thu Jun 02, 2016 1:11 pm
I agree. If it's free air still, a tuned bass reflex enclosure will be all you need. Now if you just want the XXX and a custom enclosure by all means get it because it'll hit hard if properly powered. Myself I'd get a JLw6 over a XXX but that's just my taste in subs.
PostPosted: Thu Jun 02, 2016 1:45 pm
Agree 100% on the JL option.
PostPosted: Thu Jun 02, 2016 3:06 pm
Yes I have the stock enclosure still, I just want to upgrade the sub as the 500rms stock unit don't seem to meet what I am looking for.
I was thinking the xxx with the SD2 for power. I will check out the JL. I just have all wetsounds and are very happy with them and keeping my boat outside most summer I know the wetsounds hold up to the elements well.
PostPosted: Thu Jun 02, 2016 3:09 pm
I guess I will talk to my local shop and see if they can Make a enclosure that will fit under the dash that won't take up all my leg room.
PostPosted: Thu Jun 02, 2016 4:40 pm
There is no enclosure in a 2012 is what we are saying. It's just a panel and air back there. Your stock sub in a REAL enclosure will sound pretty damn good actually
PostPosted: Thu Jun 02, 2016 5:55 pm
I gottcha now.. ya it's just the plastic panel in my boat. Thank you!
PostPosted: Sat Jun 04, 2016 7:42 am
Arc Audio 15" is what I run... just upgrade; you'll be happier when Wiz Kalifa comes on your playlist... lol
-aha-
Users browsing this forum: Google Adsense [Bot] and 38 guests
