It is currently Tue Jul 08, 2025 5:52 pm
 Post subject: Swim Platform - Black mold spots
PostPosted: Mon May 23, 2016 10:44 am
Anyone have any suggestions in a method to remove black mold spots that have appeared on my swim platform. Thanks in advance.
 Post subject: Re: Swim Platform - Black mold spots
PostPosted: Mon May 23, 2016 11:07 am
First time in my life I've heard of a platform getting mold. How is your boat stored to accomplish that?
PostPosted: Mon May 23, 2016 11:24 am
My rear stock pads did it (ones next to cup holders behind engine hatch) cover on outside all winter. I did not clean them just replaced.
PostPosted: Mon May 23, 2016 1:09 pm
I could see anything under a cover that traps moisture. I know there are platform covers made custom as well but just an uncovered platform that has good air exposure sounds unusual.
PostPosted: Mon May 23, 2016 5:43 pm
Must be in Florida. If boat is outside and in shade, the humidity and morning dew will settle on the flat surface and cause this to happen.
i used comet with light brushing (soft bristle brush) then applied quality marine vinyl protection. It helps repel the water but it makes surface a little more slick at first.
This probably shouldn't be done too often. Sometimes I take the platform off and keep it in garage if the boat will be sitting for more than a week. That's a two person job, platform is awkward and heavy to remove.
PostPosted: Mon May 23, 2016 7:07 pm
Mine gets them too. Some purple power or any other mold remover and a scrubber will take most of it off.
PostPosted: Mon May 23, 2016 8:40 pm
We had to replace our old Bu platform pad, it tracked black into the boat. The brand new gray pad had mildew spots almost immediately. Dealer said just to clean it regularly. It's "normal"... It's indiana...
PostPosted: Mon May 23, 2016 9:00 pm
I have a NIB swim platform pad if any of ya'll need a new one.
PostPosted: Tue May 24, 2016 10:20 am
Thanks for all the input, but boat sits in a covered boat dock on a a lift with the swim platform exposed to the elements in Missouri. I'm truly puzzled how this would occur, but I'm happy to hear it's not uncommon. Just doesn't make sense???
PostPosted: Tue May 24, 2016 10:49 am
I like to have a spare for my T23
