It is currently Sat Oct 24, 2026 3:55 pm
 Post subject: drain lines on 750b rear sacks kinked above hard tanks.
PostPosted: Fri May 13, 2016 10:00 am
I just picked up a 2014 t22 with plug and play the rear sacks in the back seem to take forever to drain. When i looked under the sacks both drain lines looked severely kinked does this happen with all of them should i put a 45 on the bag? any thoughts would be appreciated.
 Post subject: Re: drain lines on 750b rear sacks kinked above hard tanks.
PostPosted: Fri May 13, 2016 9:54 pm
Cut them shorter
