It is currently Tue Dec 30, 2025 9:06 pm
 Post subject: Wakeboard setup
PostPosted: Mon Apr 25, 2016 12:38 am
What does everybody run for wakeboard ink to get best wake?
Sent from my iPad using Tapatalk
 Post subject: Re: Wakeboard setup
PostPosted: Mon Apr 25, 2016 6:18 am
2016 T23
Hard Tanks Full
Bow Sac Full with extra 500 in front walkway
Rear 1100's 3/4 full wedge down
350 motor OJ945 prop
PostPosted: Mon Apr 25, 2016 9:05 am
Gibbs - Do you find you burn a considerably more gas when you use the wedge?
I run hard tanks full, pnp full (750s), and triangle on seat bow sack up to half full with no wedge.
At times I'd go for only filling the 750s half way and dropping the wedge. Seems like this gives a similar wake size with a tiny bit more peak? But, I burn through the fuel this way.
335 engine, A20, 2313 prop.
________
PostPosted: Mon Apr 25, 2016 12:20 pm
Can't tell much difference now with the oj prop. I did notice more with the factory acme 1235
PostPosted: Mon Apr 25, 2016 12:28 pm
On my new A20 I filled the center and front ballast (bag under the seat) and dropped the wedge. There were a few people in the boat. Wake was clean with a nice peak. The wedge seemed to help get me higher into the air (as opposed to farther laterally). Boat drives like a dog with the wedge down and uses a ton of gas!
PostPosted: Mon Apr 25, 2016 12:33 pm
What is typical hours for a tank of gas? I'm getting the 2016 A24 with 65 gallon tank and 409 engine.
PostPosted: Mon Apr 25, 2016 2:02 pm
I fill mine up every two trips and average 5 hours on the motor a day. So 10 hours and never been close to running out of fuel boat usually holds around 50 to 55 gallons at fill up. 10 to 15 left over. 350 motor
PostPosted: Mon Apr 25, 2016 2:17 pm
Wow.. 1100 in the rear and factor tanks.
you guys are after knee breaking wake sizes!
PostPosted: Mon Apr 25, 2016 3:46 pm
Go big or go home!!!
Lol. I run about 500lbx2 plus wedge and all stock and arrow sac full. The wake is more than most need.
PostPosted: Mon Apr 25, 2016 6:18 pm
We surf 95% of the time. That's the reason for the 1100's.
