It is currently Sat Oct 24, 2026 1:54 am
ThatGuy
Post subject: Re: Rear compartment won't drain Posted: Wed Mar 23, 2016 8:03 am |
Joined: Thu Jan 08, 2015 6:29 pm Posts: 538 Location: Ohio
Good news! Hopefully that's the only hiccup you have. Enjoy the boat!
_________________ 2015 T22 - SOLD
Stuart870
Post subject: Re: Rear compartment won't drain Posted: Mon May 30, 2016 5:24 am |
Joined: Sun Oct 05, 2014 6:28 pm Posts: 60 Location: Arkansas
What's the simplest/quickest way to access the left rear drain pump?
dustinjean
Post subject: Re: Rear compartment won't drain Posted: Mon May 30, 2016 7:27 am |
Joined: Wed Sep 03, 2014 5:19 am Posts: 457 Location: Mt. Washington, KY
Remove the plastic covering it closest to the transom should be 3 or 4 screws and will lift straight off and the pump is there screwed into a fitting that goes into the hard tank
_________________ 2014 A24
Users browsing this forum: No registered users and 10 guests |
