It is currently Mon Jul 07, 2025 11:15 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Be sure to replace your impeller
PostPosted: Tue Feb 14, 2012 11:02 am
Johnnydefacto wrote:
alright ed... when is the first trip that us guests can come out?
haha... probably by April. I can't wait to start enjoying the home, rather than working on it!
PostPosted: Sun Feb 26, 2012 3:18 pm
Just replaced mine. After busting a knuckle trying to get the impeller out, I opted for the Walter method. :) The allen bolts are 5/16. To get the hoses off, I used a flathead and sprayed some soapy water in there. Came off without a problem. I took some pics labeling exactly what needs to be removed for the mechanically inclined. Thanks for the write up Walter!
Two hoses
3 5/16" allen bolts and 1/2" bolt
PostPosted: Sun Feb 26, 2012 4:58 pm
Here's the part you need if you order outside your dealer. Johnson 812
PostPosted: Sun Feb 26, 2012 7:44 pm
Walter will you come up and change mine ? Lol
PostPosted: Sun Feb 26, 2012 7:46 pm
How much does the impeller cost ?
PostPosted: Sun Feb 26, 2012 7:49 pm
I sure will if you buy the plane ticket I'll do it for free and furnish the part! Lol anything to get out of the desert for a bit
PostPosted: Sun Feb 26, 2012 8:05 pm
Thanks for the extra pics and part number Nasty
PostPosted: Sun Feb 26, 2012 8:10 pm
The part runs about 40 dollars. I agree with replacing it yearly- cheap insurance. I've seen one of these grenade inside and it's a PITA removing all the parts to find the broken off impeller fins.
PostPosted: Sun Feb 26, 2012 10:00 pm
I have always removed the pump to change the impeller. I was in a hurry this time and was able to replace it without removing the pump... If you want to try not removing it, this is what I did -- I laid on top of the engine, took the face of the pump housing off, wedged two large screwdrivers on each side of the impeller and popped it out - It worked well.
PostPosted: Mon Feb 27, 2012 8:28 pm
I'll try the large screwdrivers next time. I was using two of them, but not being able to see what you were doing and engine digging into my chest killed that method for me! It would have probably worked better had I sprayed some lube in there prior to removal.
Users browsing this forum: Google [Bot] and 46 guests
