It is currently Fri Jan 02, 2026 8:16 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: New prop
PostPosted: Mon Jan 18, 2016 2:13 pm
Looking for a new prop for the T23. I'm currently running the 1235 and looking at 2315 for next year any thoughts.
2016 T23
350 motor
Full ballast with 1100's in the rear and full bow sac. Two extra 400's in the floor.
At 450' above sea level
 Post subject: Re: New prop
PostPosted: Mon Jan 18, 2016 2:19 pm
That is the Prop I am still seeing sold the most at Boardstop. I have heard that they are testing some new prop numbers on the 2016 boats. Not sure if that is just on the Malibu side.
PostPosted: Mon Jan 18, 2016 2:28 pm
My 2016 A20 with the 350 motor came stock with a 2249. 15x14.25
PostPosted: Mon Jan 18, 2016 3:41 pm
I was curious about this prop. I noticed that they had it mid-year in 2015. I know it will give it more top end with that pitch but, I wonder how the torque is since you still have the massive surface area with it being 15". Let us know how it planes fully loaded (3,600+lbs of ballast) with the wedge down.
PostPosted: Mon Jan 18, 2016 3:53 pm
2016 T23
350 motor
I had the 2315 on my 2015 T23 with the standard 350 motor. It would plane with 800lb p-n-p rear sacs, p-n-p bow sac (under seats) and an 800lb Ronix sac in the nose (on the seats) plus all the factory ballast full. I also had the wedge down in the second bigger wake setting. It would plane with just one person driving and all that weight but, if I added people I would have to drain a little bit out of the rear. Wake was still huge. I loved it. That prop is worth the money and you'll be surprised how fuel efficient the motor is.
Only down side is that the boats top speed in mirror water with no weight was about 33mph. for me that's not an issue though.
Hope this helps.
PostPosted: Mon Jan 18, 2016 4:00 pm
I have a 2249 on my 15 t22 with 350. 3200lbs of ballast and 6-8 adults no problems
PostPosted: Mon Jan 18, 2016 5:25 pm
I'm gonna order the 2315
PostPosted: Mon Jan 18, 2016 7:23 pm
Good choice. I run it as my backup. My current prop is the OJ945. From my experience (repairing 6 - 7 props) OJ makes a little more durable prop. We run my boat on the river a lot which tends to have a lot of sticks and logs. The OJ has chopped more wood without damage. It also feels a tax bit smoother as far as vibration in the wheel. Also, I am a little partial to OJ cause they are local to me.
PostPosted: Mon Jan 18, 2016 11:56 pm
I tend to agree with Dezul on that OJ's are a little more beefy props. If you ride/boat on a river prone to debris, I'd look at OJ's. If your lake is clean and no real hidden obstacles, I'd go Acme.
PostPosted: Tue Jan 19, 2016 9:54 am
+1 for the 945.
