It is currently Thu Oct 29, 2026 11:11 am
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: 4" Seat Riser GROUPBUY
PostPosted: Fri Oct 09, 2015 4:38 pm
dezul wrote:
r33pwrd wrote:
Could you guys tell me if this would allow you to shift the whole seat towards the center of the boat about an inch? I don't mind drilling holes just not sure of there is room to do it..
It is 17lbs of aluminum. It is heavy. You will definitely be able to modify it as needed. The aluminium is about .25 inch thick.
I get it but can you offset the holes an inch... in either the base or the riser.
PostPosted: Fri Oct 09, 2015 5:57 pm
The only issue I found with the riser is if you like to ride with the seat full forward you can't engage reverse fully. Slide the seat back and you're good to go.If you are going to offset the seat keep that in mind so you give yourself clearance for the throttle regardless of where the seat is positioned.
PostPosted: Fri Oct 09, 2015 9:33 pm
Do you actually ride with the seat all the way forward? If so, wow. I haven't moved mine from the fully back position since I have owned the boat two years ago.
PostPosted: Sat Oct 10, 2015 10:20 am
PostPosted: Sat Oct 10, 2015 10:21 am
PostPosted: Wed Oct 14, 2015 9:19 am
Does the riser fit a '12 model? I'm pretty sure my base is different than the ones in the pics.
PostPosted: Wed Oct 14, 2015 9:24 pm
Is the group buy still available?
PostPosted: Wed Oct 14, 2015 9:45 pm
The '12 version is different and he sells a Malibu riser on eBay for it but not sure if axis version is available in this group buy.
PostPosted: Thu Oct 15, 2015 10:52 am
Got mine in the mail...I'll wait till spring for the install.
PostPosted: Fri Oct 16, 2015 10:53 am
Ordered mine today.
Users browsing this forum: Google [Bot] and 52 guests
