It is currently Tue Nov 24, 2026 1:25 pm
 Post subject: Trans flush
PostPosted: Sat Sep 26, 2015 7:42 pm
Looking for the general consensus of the forum, are you guys flushing the transmission annually per the manuals recommendation (don't have it in front of me but I think that's the way it read) or are you doing it at the 300 hour mark?
Asking because I recently asked my dealer and they said Malibu/axis is no longer telling them to do it during the winterization process but rather during the 300 hour service.
2014 A22
 Post subject: Re: Trans flush
PostPosted: Sat Sep 26, 2015 10:38 pm
Do mine every 50 hours with the oil...
PostPosted: Sun Sep 27, 2015 5:55 am
what atf are you all using?
PostPosted: Sun Sep 27, 2015 9:10 am
I use whatever the dealer puts in..
PostPosted: Sun Sep 27, 2015 2:51 pm
I've been changing trans fluid annually (approx. 70 hrs) and buy it from the Napa parts store. It's too easy to change the oil/filter, trans, and Vdrive fluid to tow the boat 2 hours each way and pay the dealer to do it.
PostPosted: Sun Sep 27, 2015 7:23 pm
Well in that case I'm definitely going to do mine here on the next oil change. Any good references you've found/used for the steps of changing those fluids? I've got an oil extractor that I use regularly for oil changes... I'm assuming I'll need that for the trans?
2014 A22
PostPosted: Sun Sep 27, 2015 8:30 pm
I use the oil extractor and siphon it from the fill/check location of the trans and Vdrive. IMO it's much quicker and easier than an oil change. I siphon the most rear part first, then the front and refill to specs after both are empty. Just follow the manual on the type of fluid to purchase.
PostPosted: Sun Sep 27, 2015 9:09 pm
awesome, thanks for the tips Stuart.
2014 A22
PostPosted: Mon Sep 28, 2015 2:39 pm
Hey man just to clear it up, I keep seeing some people differentiate between the transmission and the v-drive. Transmission is for shifting, and v-drive is the gearing itself right?
Basically what I'm wanting to double check is if I hit both of these dipsticks seen below on my ZF45IV with the appropriate amount of Dexron III Mercon, I'm covered for the v-drive/transmission? Or is there a hidden gearbox somewhere that I'm not seeing lol.
2014 A22
PostPosted: Mon Sep 28, 2015 6:59 pm
Siphon from the locations above and refill to specs. As far as the differences in the vdrive and trans, I'd rather let someone who knows more answer that. I'm not a professional but with the help of this forum, the Malibu crew, and the manual a guy can find his way around in a short amount of time.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 123 guests
