It is currently Wed Nov 25, 2026 5:35 pm
 Post subject: Digital speed / surfgate indicator
PostPosted: Mon Aug 10, 2015 10:27 am
This past week, I was out and my digital speed and surfgate indicator just digitized / pixeled, to the point the display was unreadable. I shut the boat off and re-started it, it cleared up the display. It happened to me once again, with the same solution, shutdown and restart. Has anyone experienced this??? Could it be a ground wire or is the unit going bad?? If it's the unit, is it easy to remove from the dash in lieu of trailering it to the dealer 2 hrs away. Thanks in advance.
 Post subject: Re: Digital speed / surfgate indicator
PostPosted: Mon Aug 10, 2015 11:15 am
It's VERY easy to remove it.
PostPosted: Thu Sep 10, 2015 10:23 am
Wish you would expand on the removal process, but the good news is that it hasn't occurred again.
PostPosted: Thu Sep 10, 2015 10:39 am
It removes by removing the two nuts on the back of the display. Then you pull it out the front.
Users browsing this forum: No registered users and 73 guests
