It is currently Mon Nov 23, 2026 9:15 am
 Post subject: Dash cracked.
PostPosted: Mon Jun 15, 2015 9:10 pm
Just wondering if anyone else has ever had their dash crack. My dash on the drivers side of the boat cracked where the dash is screwed down to the side of the boat just above the throttle. I forgot to take a pic before I dropped it off at the dealer to be replaced. Boat is a 14 t22.
14 t22 with sg
 Post subject: Re: Dash cracked.
PostPosted: Mon Jun 15, 2015 9:28 pm
If I understand your description correctly, I have a very small crack in the same spot on my 15 a22, never really thought about getting it fixed tho cause it so so small
PostPosted: Mon Jun 15, 2015 10:52 pm
It's about 1 inch long going from the screw hole to the outer edge of the plastic. I figured if it didn't get fixed there is a good possibility that it could completely break off. They are replacing the whole dash on the drivers side. I do not think that it's acceptable for the dash to crack for the price we pay for our boats. If I were you I would talk to your dealer and get it changed in the off season. I would have waited but I have no time to use my boat for the next couple of weeks so they can change it now.
14 t22 with sg
PostPosted: Tue Jun 16, 2015 9:45 pm
My 15 T22 was delivered four weeks ago with the same crack. New dash installed after two week dealer order from factory. Had a few minor issues with connections and electronics after, but I fixed myself, no problem.
PostPosted: Sun Jun 21, 2015 5:01 pm
My '14 T22 also has the crack on the right side. Seems it was caused by over tightening the dash screw. Hopefully dealer doesn't balk over this repair.
PostPosted: Mon Jun 22, 2015 6:41 pm
mine was cracked there also, dealer replaced under warranty
PostPosted: Sun Jun 28, 2015 8:42 am
Just spent a week on Lake Nantahala in NC, disappointed with a number of electrical issues resulting from replacement of cracked dash. Seems that dealer didn't connect my switches/wires. Intermittent Ballast pumps not working, lights wouldn't turn on, Bilge stopped working. I spent a lot of time under the dash working the fittings to get connections tightened. Very disappointed with quality. I'm hoping it's a dealer issue and not a serious defect with the 2015 T22 electrical system. Anybody else have this issue?
PostPosted: Mon Jun 29, 2015 8:05 am
Not a single electrical problem on my 15' A24. Sounds like a dealer issue more than an Axis issue.
PostPosted: Mon Jun 29, 2015 10:43 am
*thumbs up*
PostPosted: Sun Nov 22, 2015 1:00 am
Image. This's what mine looks like, it's at the dealer getting replaced. Hopefully everything gets rewired correctly.
