It is currently Sun Nov 15, 2026 6:53 am
 Post subject: Re: How to build a subwoofer cover like these?
PostPosted: Mon Jan 05, 2015 9:30 pm
idahosurf wrote:
1/2" birch plywood with a sealing primer and bed liner sprayed on. The grate is expanded metal that I coated with bed liner. The tricky part was getting the right bottom corner to sit flush. Originally I bolted the face on but ended up going to Velcro. I also added subwoofer cloth to hide the cavity and sub.
Btw, mine is the first picture. Sorry I didn't see this thread earlier.
Thanks!
Which bedliner did you use? I just did my amp rack and it didn't turn out as textured as I wanted.
PostPosted: Mon Jan 05, 2015 10:43 pm
Whichever brand Home Depot sells. I will look and see if I have any left. I will post if I do. It has a really nice texture without being to much like wall texture.
PostPosted: Mon Feb 09, 2015 10:27 am
finally finished mine... looks great and doesn't vibrate!
1/2"mdf
sealed with resin
sprayed bedliner
secured with velcro
Thanks for all of the tips.
PostPosted: Fri Feb 13, 2015 8:25 am
1/2"mdf
sealed with resin
sprayed bedliner
secured with velcro
Pics or we don't believe you :D
PostPosted: Fri Feb 13, 2015 10:01 am
You feel sealed sounds better than ported?
PostPosted: Fri Feb 13, 2015 12:53 pm
The answer to that will always depend on type of music and personal preference. It's not that one is better or worse than the other, they are just different.
PostPosted: Fri Feb 13, 2015 7:00 pm
idahosurf wrote:
1/2"mdf
sealed with resin
sprayed bedliner
secured with velcro
lol... in this pic you can see the speaker more than you can in person.
this set up sounds great. I paired the type r with an alpine 1100 w amp
PostPosted: Mon Feb 16, 2015 9:52 pm
Looks awesome!
