It is currently Sat Oct 24, 2026 12:08 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: Sub enclosure ideas.
PostPosted: Fri Sep 19, 2014 2:51 pm
I decided to get a little creative too over the past couple of days. Sealed box with a lexan/plexi front. Going to re-do the plate/cover in front of the box when I get a chance, but itll work for now.
PostPosted: Thu Sep 25, 2014 7:03 am
Some of you guys should really try a ported box. Properly built it can add 2 to 3 db.
PostPosted: Thu Sep 25, 2014 7:56 am
It really depends on the design of the sub and application as to whether any gains would be seen with a ported box versus sealed.
PostPosted: Thu Sep 25, 2014 12:09 pm
I'm well aware. I have a room full of trophies from my stereo competition days.
PostPosted: Fri Sep 26, 2014 10:46 am
Loving this thread for a winter project. I have the Exile sub...looks like 1.25cu/ft should do well with a sealed box. I hope I have enough room to keep my factory sub bezel.
PostPosted: Fri May 08, 2015 6:37 pm
I was just reading through this thread hoping to see how to remove that kick panel. I have a T22 and want to remove that panel to have a look at the heater core and all the rest of the wiring in there. I see only one screw at the top left holding it, I pulled out the sub woofer and there is a sealed plastic enclosure there with no access. is the panel glued or am I just missing something?
2014 Axis T22
PostPosted: Sun May 24, 2015 12:05 am
Bump! Does any one have pics or know how that kick panel under the helm comes loose on a 2014 T22. I want access to that area and can't seem to get it loose. I want to look at the heater core as well as run some new wires and any help removing that panel would be greatly appreciated!
2014 Axis T22
