It is currently Mon Nov 09, 2026 3:42 am
 Post subject: LED light bar wiring
PostPosted: Sun Sep 07, 2014 2:18 pm
Going to put two light bars on the tower of the a22. One 12 inch facing forward and one 24 facing the back. The front one I was going to hook up with the docking lights. The rear I was going to hook up to the spare acc switch on the dash.
My question is, where is the grounding under the dash and is it as easy as plugging the positive to the spare male end on the acc switch, and wire tapping into the docking lights?
All the lights have the relays. And the acc switch has power.
Any help would be appreciated!
Kirk
 Post subject: Re: LED light bar wiring
PostPosted: Sun Sep 07, 2014 3:54 pm
Its under the helm on the the starboard gun whale behind the sub woofer panel
PostPosted: Sun Sep 07, 2014 11:01 pm
which light bars are you putting on? can you send some pics when you are done, maybe an install note etc? just in case others wanna do it to?
cheers
best of luck with it!
2015 Axis A22
Liquid Force Edition
409HP Engine Upgrade
And a few other options!
