It is currently Tue Nov 10, 2026 5:50 am
 Post subject: plug and play T22
PostPosted: Sat Aug 30, 2014 12:32 pm
hello guys
just received our new T22, was plugging the bags, pretty straight forward at the back, but in the bow I m not sure
Is there a vent ??
I have a 650 from straight line
and 2 750 at the back
what king of connection elbow, straight ?? do you need to cut something ? in the back the very aft drain line is very long if you don t reduce the length the bag is under the rear seat?
any tips ideas whatever
this is our first boat just love it
looking forward to reading your advise
ben
 Post subject: Re: plug and play T22
PostPosted: Sat Aug 30, 2014 10:01 pm
In the front you have to remove the y fitting to split it into three hoses. One is a drain one is a vent and the other is a fill. Hope this helps.
14 t22 with sg
PostPosted: Sun Aug 31, 2014 6:56 am
If I get a pic of mine, showing what direction each tube goes, would that be helpful? Let me know if so and I'll hop in there and take one..
Current: 14 Axis T22
Previous: 07 Malibu V-Ride
Previouser: 90 Supra Conbrio
PostPosted: Sun Aug 31, 2014 12:12 pm
thanks
the picture can be helpful,
do you need to reduce the length of an hose, when i lay down the bag, there is a plug on the right side and the hose that is suppose to go to this one is pretty long then ?
same for the rear bags with the draining
PostPosted: Mon Sep 01, 2014 11:53 am
Not sure if this actually helps or not. Hopefully.
