It is currently Wed Oct 28, 2026 8:33 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2, 3  Next
 Post subject: 335 vs 400 hp Axis A-22
PostPosted: Wed Jul 14, 2010 7:56 am
The Axis A-22 has been a boat I have had my eye on since they have came out and my dealer has a 2009 demo boat they are selling for a discounted price that has the 335 hp engine. I know they come with two different engines and I wondering what engine most people have in there boat. I know with running the plug and play system a person should have the power prop, but if you run additional ballast is the 400 hp engine worth the money or is the 335 hp engine enough power
 Post subject: Re: 335 vs 400 hp Axis A-22
PostPosted: Wed Jul 14, 2010 10:18 am
I have the 335 and after installing the acme 14.5/12.75 it have no problem getting out of the hole with3000 # additional ballast wedge and 8 people in the boat. Crusing speed is about 28 . Runs about 34 wide open.
PostPosted: Thu Jul 15, 2010 3:57 pm
same for us, 335 with plug n play, had 10 people in the boat at Shasta, all tanks/bags full, wedge down with the acme wake prop, and boat pulled just fine! must say that the wake was huge with that many peeps in the boat!
2010 Axis A22
PostPosted: Thu Jul 15, 2010 10:41 pm
our local dealer orders all his with the 335. I think adding the 1235 prop would do the trick for sure. you can get the 1615 for $521 or the 1235 for $582
http://www.boardstop.com/product_info.p ... ts_id=4610
http://www.boardstop.com/product_info.p ... ts_id=3347
so what kind of deal are you getting on the 09?
PostPosted: Fri Jul 16, 2010 9:15 pm
I have the 400hp motor. Its a nice to have but not needed - an upgraded prop is a must have.
PostPosted: Sun Aug 08, 2010 5:38 pm
hey do you happen to know the part # of your prop? I think i need just what you have....
PostPosted: Mon Aug 09, 2010 1:57 pm
1615 125m-35m. It is a great prop for getting on plane fast. Loaded heavy
PostPosted: Wed Aug 11, 2010 9:04 pm
Thanks dbragg I ordered one today and called Rinda Technologies and ordered a diagnostic scanner that will read the boat so I can figure out that damn service required message that keeps popping up.
PostPosted: Thu Aug 12, 2010 9:59 am
Do you not have a dealer that will check out your problem ?
Let me know how you like the prop
PostPosted: Sun Mar 27, 2011 7:35 pm
Hey Dbragg you talked about crusing at 28 and wide open at 34 with the acme 14.5/12.75 fully loaded 3000# and people on board what will it do with no weight at all. and what is your rpm at 28 and loaded
