It is currently Mon Mar 23, 2026 4:18 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Hot off the press! 2015 A24
PostPosted: Fri Aug 15, 2014 7:41 am
I chatted with a friend of mine (dealer) who runs an A24 with an Indmar 409ss and Torque prop. Those wakeboard RPMs are pretty well inline with what he is currently running.
PostPosted: Fri Aug 15, 2014 8:31 am
Same motor and 2419 I'm running in mine. With 5150lbs of ballast then the wedge I run the same RPMs.
PostPosted: Tue Aug 19, 2014 7:44 am
I gave the wrong rpm's for wakeboarding, sorry about that.
20.0 mph = 3500 rpm
22.0 mph= 3650 rpm
These rpm's are very close to our previous boat which had the PCM ex 343, 1.48:1 tranny ratio and 1235 prop.
That's only 300-400rpm's higher than surfing. Not bad really.
Also you only need half throttle for hole shots and then it seems like you only need 10% throttle to hold speed so this 450 is barely trying
PostPosted: Tue Aug 19, 2014 11:44 am
Anyone follow Trevor Maur on instgram? He mentioned his 15' A24 has an LS3. I wonder if they are still using MP for the 450hp option.
PostPosted: Tue Aug 19, 2014 12:18 pm
2015 Axis are entirely PCM.
PostPosted: Tue Aug 19, 2014 1:15 pm
He's likely referring to the PCM version of the 450.
PostPosted: Tue Aug 19, 2014 1:54 pm
Which decidedly ain't an LS3.
PostPosted: Wed Aug 20, 2014 12:59 pm
If you want an ls3 A24, you can always buy mine...
PostPosted: Thu Aug 21, 2014 1:20 pm
Or mine :)
PostPosted: Thu Aug 21, 2014 2:57 pm
Looks like you already have some interest in the classifieds!!!!
Users browsing this forum: Majestic-12 [Bot] and 22 guests
