It is currently Mon Mar 23, 2026 3:39 pm
 Post subject: New Axis Owner -Have some questions
PostPosted: Thu Aug 07, 2014 1:41 pm
Hello. I just recently purchased a 2011 A22. So far I love it, but I do have some questions.
So I was using the wedge the other day and when I put it up I noticed one of the locking pins was completely gone! Is this common? Where do I get more pins?
The boat has a black Axis cover. When I take the cover off, I notice it turns the white on the interior brown. After it gets direct sunlight for awhile the brown fades away. Is this common? I did check for mildew in the cover and did not see any, it actually looks pretty clean actually.
My boat does not have depth finder, but when I start it there is a section on the gauge that says, "Depth," am I able to just add to the system with a sensor, like a plug and play deal and read it on the stock gauges? If so, where would I go to get this?
I need some more wakeboard racks, recommendations?
Where is the best place to get stainless steel cup holders? The dealer?
Thank you for the input.
 Post subject: Re: New Axis Owner -Have some questions
PostPosted: Thu Aug 07, 2014 1:47 pm
Also, I noticed some the Axis boats have pading in the front on the bow. Can I only get that from the dealer?
PostPosted: Thu Aug 07, 2014 2:25 pm
Don't know about the depth finder. Deck trac non skid pieces are factory / dealer only. Do you want swivel it stationary rack?
With the cover I think some folks with this issue use foam swim noodles strategic placed to keep the cover from contacting the vinyl.
Cup Holders thread link below
viewtopic.php?t=2646
PostPosted: Thu Aug 07, 2014 2:35 pm
Swivel racks would be nice. But don't really care that much.
PostPosted: Thu Aug 07, 2014 2:59 pm
oops, double post, see below
PostPosted: Thu Aug 07, 2014 3:00 pm
If you are missing the pins, you can get replacements.
https://www.bakesonline.com/detail.aspx?ID=2649
Down at the bottom in the "also recommends" section you can get the other parts as well.
There are 2 slide pins. 2 thumb pins and 1 spring. The spring goes in the middle with a slide pin on either side, then the thumb pins screw into the slide pins to hold them in place and let the wedge down.
PostPosted: Thu Aug 07, 2014 3:14 pm
The depth finder is a thru hull model. If you look where your paddle wheel is, on the opposite side (starboard) is there a similar hole that is plugged up?
PostPosted: Sat Aug 09, 2014 11:38 pm
Yes it does have that hole
PostPosted: Sun Aug 10, 2014 6:35 am
Is that pin not under warranty? I forget the period for that stuff. Easy reinstall nonetheless. Just be careful as Malibu and axis use different pins.
Current: 14 Axis T22
Previous: 07 Malibu V-Ride
Previouser: 90 Supra Conbrio
PostPosted: Sun Aug 10, 2014 6:38 am
And yes it's a somewhat common problem. (Wedge pins falling out). I'd recommend to continually check the thinner pins (the ones you squeeze together) to make sure they are tightly threaded on (righty tighty)
