It is currently Fri Mar 20, 2026 7:37 am
 Post subject: Sick on my stomach
PostPosted: Fri Jul 25, 2014 8:24 pm
Well I decided to take the wrap off of my boat. It was marked up from the previous owner so it was time. I had to take the rub rail off to get the wrap out from under it. Well when I removed the rub rail.. It looks like they banged into something hard right under the rub rail and THE HULL AND TOP ARE SEPARTATING!!!!! NOW WHAT?? Anybody have this happen? I contacted the dealer I bought it from. The section that is separating is about 3' long. He says I will be ok driving the boat tomorrow without towing..
Unbelievable!!!
 Post subject: Re: Sick on my stomach
PostPosted: Fri Jul 25, 2014 9:01 pm
Your wrap was one piece? The Vandall wrap on my 2010 are split top and bottom, either way the damage sucks, they'll probably just squirt some more of the goo in the crack. How was the rail attached just out of curiosity?
PostPosted: Sat Jul 26, 2014 4:21 am
Yea the wrap was split in 2 but it was too far under the rub rail to get off. This really sucks but I am glad I found it so I can get it fixed. I don't think it will be a major deal to fix.... hopefully
PostPosted: Sat Jul 26, 2014 9:46 am
Pics?
PostPosted: Sat Jul 26, 2014 7:48 pm
Happened on my 98 Sportster. Dealer took off rub rail and re-applied the adhesive and rivets.
2018 T22
PostPosted: Mon Jul 28, 2014 8:13 am
Here is a video... This shows better than the pics
http://vimeo.com/101919092
PostPosted: Mon Jul 28, 2014 8:16 am
I was curious if anyone else has had their rub rail off...are the rivets still in yours?? I have holes the whole way around but nothing in them..did they take them out?
PostPosted: Mon Jul 28, 2014 10:05 am
wow...that was under the wrap?
PostPosted: Mon Jul 28, 2014 10:10 am
That sounds suspicious. The way it was explained to me was that the upper and lower hulls have a flange that overlaps. That flange is sealed with adhesive, then rivets are used to add strength to the joint. The rub rail covers the joint/rivets. When mine was taken apart, the rivets were drilled out, but the dealer replaced them after they applied the sealant.
2018 T22
PostPosted: Mon Jul 28, 2014 10:12 am
The video is prompting for a password.
