It is currently Tue Jul 01, 2025 4:49 pm
 Post subject: dead on the water. helphelp
PostPosted: Fri Jul 04, 2014 6:43 am
It acts like the fuel pump is out. I have a full tank of gas. Does any one know what kind of pump they use
2013 A22
 Post subject: Re: dead on the water. helphelp
PostPosted: Fri Jul 04, 2014 7:03 am
Can you here the pump prime when you switch the key on?
PostPosted: Fri Jul 04, 2014 7:04 am
Make sure your safety lanyard is attached properly too.
PostPosted: Fri Jul 04, 2014 7:17 am
Also make sure the throttle lever is in neutral
PostPosted: Fri Jul 04, 2014 9:04 am
I had an issue like that and had to replace the fuel relay censor.
PostPosted: Mon Jul 07, 2014 11:36 am
Ended up being water in the the distributor cap. Sorry not good cell service at the lake we figured it out in about an hour. Thanks for all of the input
2013 A22
PostPosted: Tue Jul 08, 2014 8:21 am
Glad you are back in business - what was it??
PostPosted: Wed Jul 09, 2014 6:47 pm
Moisture in the distributor cap. Don't know how that happened. But my dealer was on the way down on the 4th of July that's good service
2013 A22
Users browsing this forum: No registered users and 92 guests
