It is currently Thu Mar 19, 2026 9:48 pm
 Post subject: Ballast Hoses Set Up
PostPosted: Sun Jun 29, 2014 6:09 am
Can someone post a pic of what their rear setup looks like and the front bag. I feel like the front takes on a lot more air than it should. I just want to see what your hoses look like for the rears especially... My fill is was too long and kinking up I know I will have to cut it... I'd just like to see what others have done.
2015 T22
 Post subject: Re: Ballast Hoses Set Up
PostPosted: Sun Jun 29, 2014 8:59 am
You shouldn't be getting any air in the front bag because of the vent, so you might of hooked up a wrong hose some where. And what size of bags do you have in the back because that may charge how you want to cut the hoses in the back.
PostPosted: Sun Jun 29, 2014 1:01 pm
It's got Ronix 800's
2015 T22
PostPosted: Mon Jun 30, 2014 11:50 am
Anyone??
2015 T22
PostPosted: Mon Jun 30, 2014 12:13 pm
Take a look at my 2014 pnp thread my vent thread. The front does get some air in it but if you have the vent hooked up right, you should be able to fill it till most of the air is out and you are dumping over the side. I like to fill my front bag while the boat is turned off. It seems to get less air in it.
PostPosted: Mon Jun 30, 2014 12:39 pm
Thanks Dezul... But that doesn't show how it comes from the rear shut off/on valve and the addition drain hose toward the transom... The way it's sitting there looks like it will kink no matter what. Did you all move the valve?
2015 T22
PostPosted: Mon Jun 30, 2014 1:21 pm
Mine kinked. My dealer moved them to the top rear hole when I took it in for routine service. I have since cut off the kinked part and left it on the rear hole. The addition of the vent hoses keeps the bags from getting full of air. They actually stay deflated while filling. No air pockets or anything. It makes it easy to guage the water level in them.
PostPosted: Mon Jun 30, 2014 1:26 pm
Give me 30 minutes or so and I can get you pictures of anything you want to see. Post here exactly what you want pictures of and I will take them.
PostPosted: Mon Jun 30, 2014 6:20 pm
Shut off valve location... How the hose runs from that and extra drain hose... And Center hose configuration. Thanks dude.
2015 T22
PostPosted: Mon Jun 30, 2014 6:55 pm
you're a little late but why not. My dogs want to go play outside.
