It is currently Thu Jul 02, 2026 9:23 am
 Post subject: Re: I was scered !!!
PostPosted: Wed Apr 16, 2014 9:55 am
I have a blade mcx-p that I try to fly. I can hover with tail facing me but its real twitchy and I haven't mastered the other directions. I took off from the exact location of the picture, and all you have to do to correct the tilt on take off is a little right stick correction .... I have always been told that you have to fly it off the ground and back on to it. which basically means if the blades are spinning you should be ready to make stick adjustments regardless of if its in the air or on the ground.
PostPosted: Thu Apr 17, 2014 7:56 pm
That is legit
PostPosted: Fri Apr 18, 2014 3:53 am
I have been eyeballing the phantom for a while now. I was also looking at the 3drobotics iris. That's cool that you have one and are using it to get some wakeboard shots. Keep posting about your experience with it. Can you lock the altitude in the software? I was hoping that there would be some way to get it to gps follow a signal of some sort. It has a return to home built in if it goes out of range, but that probably doesn't work for the boat. This may still need some time before it's ready for full boat follow autonomous flight...but very cool. Keep us posted. Thanks!
2014 Axis T22
PostPosted: Fri Apr 18, 2014 8:51 am
With a standard set up you can not lock in an altitude, however DJI does have a few way point systems. I don't have a way point system but my understanding of how the system works is you choose destinations, times, altitudes, how long at each destination, ect and then its able to follow the given instructions autonomously from take off to landing. As far as I know right now there is no software for it to do an autonomous following of a gps signal. the way the return to home feature works is once power is turned on it goes threw a series of checks and relays the info threw a sequence of blinking green and red lights. once 6 or more gps satellites have been communicated with it records its current gps location and sets this location as the return to home location. so obviously a moving boat this will not work, but sitting still, anchored, it will come close enough for you to recover it. the return to home function is only triggered by 1 of two options first is a toggle switch on the remote, second is loss of signal from the remote. (ie battery failure in controller, or beyond 1000 meter limit of stock controller)
PostPosted: Fri Apr 18, 2014 9:24 am
My local dealer and good friend Thomas got one of these. Here is a quick edit put together of my buddy John riding behind the Pro Marine A24, all shot with Phantom II Vision. Driver is yours truly.
http://vimeo.com/90851651
PostPosted: Fri Apr 18, 2014 12:47 pm
Damn that's cool!
PostPosted: Fri Apr 18, 2014 1:44 pm
How fast was that? the speed conversion is close to ride speed and I was wondering if it would keep up. watching that I can't wait to try surfing and wakeboarding with it ...... Have you seen the phantom 2 vision plus?
PostPosted: Fri Apr 18, 2014 1:45 pm
We were wakeboarding at 22mph. It keeps up with the boat just fine! You can even see that at times, it was faster than the boat.
What is the vision plus?
Oh I see now, better camera and gimbal. Looks awesome for sure. I haven't gotten to pilot the quad yet, but I can't wait to get my hands on it. I just know that once I get to fly it, I am going to be hooked and buying one of my own.
PostPosted: Fri Apr 18, 2014 1:48 pm
oh ........ just the phantom 2 vision with a 3 axis gimbal .......
PostPosted: Fri Apr 18, 2014 3:13 pm
I hate you all.
Users browsing this forum: Majestic-12 [Bot] and 26 guests
